UOS 通过 Nginx 托管 .Net Core 服务
| 硬件环境 | 软件环境 | IP 地址 |
| KVM 虚拟机 | UOS 服务器版[X86] 1032 | 192.168.122.252 |
UOS + .Net + Nginx
一、准备 .Net 环境
1、解压缩软件包
# mkdir dotnet
# tar -zxf dotnet-runtime-3.1.15-linux-x64.tar.gz -C dotnet/
# tar -zxf dotnet-sdk-3.1.115-linux-x64.tar.gz -C dotnet/
2、优化路径,配置环境变量
# ln -s $HOME/dotent/dotnet /usr/bin/dotnet
# vim .bashrc
export DOTNET_ROOT=$HOME/dotnet
export PATH=$PATH:$DOTNET_ROOT
export MASBuildSDKPath=$HOME/dotnet/sdk/3.1.115/Sdks/
# source .bashrc
二、编译运行项目
1、创建一个mvc项目
# dotnet new mvc -o ntmvc
The template "ASP.NET Core Web App (Model-View-Controller)" was created successfully.
This template contains technologies from parties other than Microsoft, see https://aka.ms/aspnetcore/3.1-third-party-notices for details.
Processing post-creation actions...
Running 'dotnet restore' on ntmvc/ntmvc.csproj...
Restore completed in 49.24 ms for /root/ntmvc/ntmvc.csproj.
2、修改 Startup.cs 文件
## 首先切换到项目目录ntmvc,修改Startup.cs文件
# cd ntmvc/
# vim Startup.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Threading.Tasks;
using Microsoft.AspNetCore.Builder;
using Microsoft.AspNetCore.Hosting;
using Microsoft.Extensions.Configuration;
using Microsoft.Extensions.DependencyInjection;
//添加引用
using Microsoft.AspNetCore.HttpOverrides;
app.UseMvc(routes =>
routes.MapRoute(
template: "{controller=Home}/{action=Index}/{id?}");
//添加下面的代码
app.UseForwardedHeaders(new ForwardedHeadersOptions
ForwardedHeaders = ForwardedHeaders.XForwardedFor | ForwardedHeaders.XForwardedProto
app.UseAuthentication();
3、生成项目
## 运行下面的命令生成项目
# dotnet publish -c Release
Microsoft (R) Build Engine version 16.4.0+e901037fe for .NET Core
Copyright (C) Microsoft Corporation. All rights reserved.
Restore completed in 41.98 ms for /root/ntmvc/ntmvc.csproj.
ntmvc -> /root/ntmvc/bin/RElases/netcoreapp3.1/ntmvc.dll
ntmvc -> /root/ntmvc/bin/RElases/netcoreapp3.1/ntmvc.Views.dll
ntmvc -> /root/ntmvc/bin/RElases/netcoreapp3.1/publish/
运行完后生成一个
bin文件夹,bin 文件夹中会包含 Release 文件夹,在 Release 文件夹中的netcoreapp3.1 文件夹中,会包含可以发布的内容,即publish文件夹。
4、运行项目
## 切换到publish 文件夹,运行命令
# dotnet ntmvc.dll
info: Microsoft.Hosting.Lifetime[0]
Now listening on: http://localhost:5000
Now listening on: https://localhost:5001
Application started. Press Ctrl+C to shut down.
Hosting environment: Production
Content root path: /root/ntmvc/bin/Release/netcoreapp3.1
5、编写成 service 服务,是指开机自启
# vim /etc/systemd/system/kestrel-ntmvc.service
[Unit]
Description=Example .NET Web MVC Application running on UOS
[Service]
WorkingDirectory=/root/ntmvc
ExecStart=/usr/bin/dotnet /root/ntmvc/bin/Release/netcoreapp3.1/publish/ntmvc.dll
Restart=always
RestartSec=10 # Restart service after 10 seconds if dotnet service crashes
SyslogIdentifier=dotnet-example
User=root
Environment=ASPNETCORE_ENVIRONMENT=Production
[Install]
WantedBy=multi-user.target
查看结果
# systemctl daemon-reload
# systemctl restart kestrel-ntmvc.service
# systemctl status kestrel-ntmvc.service
● kestrel-ntmvc.service - Example .NET Web MVC Application running on UOS
Loaded: loaded (/etc/systemd/system/kestrel-ntmvc.service; disabled; vendor preset: enabled)
Active: active (running) since Thu 2021-05-13 15:36:32 CST; 1s ago
Main PID: 1622 (dotnet)
Tasks: 17 (limit: 2313)
Memory: 30.6M
CGroup: /system.slice/kestrel-ntmvc.service
└─1622 /usr/bin/dotnet /root/ntmvc/bin/Release/netcoreapp3.1/publish/ntmvc.dll
5月 13 15:36:32 uos-PC dotnet-example[1622]: info: Microsoft.Hosting.Lifetime[0]
5月 13 15:36:32 uos-PC dotnet-example[1622]: Now listening on: http://localhost:5000
5月 13 15:36:32 uos-PC dotnet-example[1622]: Now listening on: https://localhost:5001
5月 13 15:36:32 uos-PC dotnet-example[1622]: Application started. Press Ctrl+C to shut down.
5月 13 15:36:32 uos-PC dotnet-example[1622]: Hosting environment: Production
5月 13 15:36:32 uos-PC dotnet-example[1622]: Content root path: /root/ntmvc
三、配置 Nginx 托管
1、安装 Nginx
# apt install -y nginx
2、配置 Nginx 代理
# vim /etc/nginx/conf.d/proxy.conf
server {
listen 80;
server_name www.yzq1.com;
location / {
proxy_pass https://127.0.0.1:5001;
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
client_max_body_size 10m;
client_body_buffer_size 128k;
proxy_connect_timeout 90;
proxy_send_timeout 90;
proxy_read_timeout 90;
proxy_buffers 32 4k;
4、检查 Nginx 配置并重启
# nginx -t
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
# systemctl restart nginx
验证
需要添加/etc/hosts 解析
