ppd文件打包deb
创建ppd文件的存放目录,按照外设打包规范是放在/usr/share/cups/model/厂商英文名/目录下,以下使用佳能的ppd举例。 mkdir canon cd canon mkdir -p usr/share/cups/model/Canon cp ../Canon_iR2520_UFRII_LT_deepin.ppd usr/share/cups/model/Canon 编写info文件
vim info {
"appid": "com.canon.ir2520",
"name": "com.canon.ir2520",
"version": "0.0.1",
"arch": ["amd64"],
"permissions": {"autostart": false,
"notification": false,
"trayicon": false,
"clipboard": false,
"account": false,
"bluetooth": false,
"camera": false,
"audio_record": false,
"installed_apps": false
编写DEBIAN/control文件 vim DEBIAN/control Package: com.canon.ir2520 Version: 0.0.1 Section: utils Priority: optional Architecture: amd64 Depends: Installed-Size: 512 Maintainer: [email protected] Description: com.canon.ir2520 创建文件完成后目录结构应该是这样的:
canon/
├── debian
│ └── control
├── info
└── usr
└── share
└── cups
└── model
└── Canon
└── Canon_iR2520_UFRII_LT_deepin.ppd
在canon目录的上层目录执行
fakeroot dpkg-deb -b canon com.canon.ir2520_amd64.deb
当前目录生成com.canon.ir2520_amd64.deb,deb包制作完成
