kvm虚拟机运行时显示“启动域时出错”
启动虚拟机时提示“启动域时出错: Requested operation is not valid: network 'default' is not active”
查看网络名称
sudo virsh net-list
开启网络,重启虚拟机
sudo virsh net-start default
设置自动连接
sudo virsh net-autostart defaultda
关闭网络
sudo virsh net-destroy default
