apt命令提示lock异常解决方案
执行apt命名时报lock异常,异常信息为
Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable) E: Unable to lock directory /var/lib/apt/lists/
解决方案 查找下后台是否有apt进程,确认下该进程是否可以杀掉,如果可以的话,杀掉该进程
ps -aux | grep apt #找到 apt-get 那个被lock住的进程记下PID
sudo kill $PID
删掉锁文件
sudo rm /var/lib/apt/lists/lock
