查询命令
dbus-send --session --dest=org.kde.KWin --print-reply /Compositor org.freedesktop.DBus.Properties.Get string:org.kde.kwin.Compositing string:active
#返回值
method return time=1615180578.923026 sender=:1.3526 -> destination=:1.3528 serial=538 reply_serial=2
variant boolean true #true为开启,false为关闭
暂停特效
dbus-send --session --type=method_call --dest=org.kde.KWin /Compositor org.kde.kwin.Compositing.suspend
恢复特效
dbus-send --session --type=method_call --dest=org.kde.KWin /Compositor org.kde.kwin.Compositing.resume
