1. 如果未安装bash-completion,安装bash-completion。
2. 修改/etc/bash.bashrc文件,将
#if ! shopt -oq posix; then
if [ -f /usr/share/bash-completion/bash_completion ]; then
. /usr/share/bash-completion/bash_completion
elif [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
#fi 去掉前面的#号
3. 修改/etc/profile文件,在最后增加一行
source /etc/bash.bashrc
