载入中...
搜索中...
未找到
Dtk::Widget::DBlurEffectWithBorderWidget类 参考
类 Dtk::Widget::DBlurEffectWithBorderWidget 继承关系图:
Dtk::Widget::DBlurEffectWidget
 DBlurEffectWithBorderWidget (QWidget *parent=nullptr)
- Public 成员函数 继承自 Dtk::Widget::DBlurEffectWidget
 DBlurEffectWidget (QWidget *parent=0)
 DBlurEffectWidget::DBlurEffectWidget constructs an instance of DBlurEffectWidget.
int radius () const
 This property holds the radius of the blur effect.
BlurMode mode () const
 This property holds which blur algorithm to be used.
BlendMode blendMode () const
 This property holds which mode is used to blend the widget and its background scene.
int blurRectXRadius () const
 This property holds the xRadius of the effective background.
int blurRectYRadius () const
 This property holds the yRadius of the effective background.
bool isFull () const
 DBlurEffectWidget::isFull
bool blurEnabled () const
 DBlurEffectWidget::blurEnabled
QColor maskColor () const
 This property holds the background color of this widget.
quint8 maskAlpha () const
void setMaskPath (const QPainterPath &path)
 DBlurEffectWidget::setMaskPath set custom area as the effective background.
void setSourceImage (const QImage &image, bool autoScale=true)
 DBlurEffectWidget::setSourceImage image autoScale
void paintEvent (QPaintEvent *e) override
- Protected 成员函数 继承自 Dtk::Widget::DBlurEffectWidget
 DBlurEffectWidget (DBlurEffectWidgetPrivate &dd, QWidget *parent=0)
void paintEvent (QPaintEvent *event) Q_DECL_OVERRIDE
void moveEvent (QMoveEvent *event) Q_DECL_OVERRIDE
void resizeEvent (QResizeEvent *event) Q_DECL_OVERRIDE
void showEvent (QShowEvent *event) Q_DECL_OVERRIDE
void hideEvent (QHideEvent *event) Q_DECL_OVERRIDE
void changeEvent (QEvent *event) Q_DECL_OVERRIDE
bool eventFilter (QObject *watched, QEvent *event) override
- Public 类型 继承自 Dtk::Widget::DBlurEffectWidget
enum  BlurMode { GaussianBlur }
enum  BlendMode { InWindowBlend , BehindWindowBlend , InWidgetBlend }
enum  MaskColorType { DarkColor , LightColor , AutoColor , CustomColor }
- Public 槽 继承自 Dtk::Widget::DBlurEffectWidget
void setRadius (int radius)
 DBlurEffectWidget::setRadius radius 模糊区域的圆角大小 如果设定值和原值不一致会发送信号radiusChanged
void setMode (BlurMode mode)
 DBlurEffectWidget::setMode mode 设定模糊算法,默认为高斯模糊算法GaussianBlur
void setBlendMode (BlendMode blendMode)
 DBlurEffectWidget::setBlendMode blendMode 窗口混合模式,模式设定变化发送blendModeChanged信号
void setBlurRectXRadius (int blurRectXRadius)
 DBlurEffectWidget::setBlurRectXRadius blurRectXRadius 模糊区域矩形的X圆角大小
void setBlurRectYRadius (int blurRectYRadius)
 DBlurEffectWidget::setBlurRectYRadius blurRectYRadius 模糊区域矩形的Y圆角大小
void setMaskAlpha (quint8 alpha)
 DBlurEffectWidget::setMaskAlpha alpha 设置Alpha通道,值变化发送maskAlphaChanged信号
void setMaskColor (QColor maskColor)
 DBlurEffectWidget::setMaskColor maskColor 设定mask的颜色
void setMaskColor (MaskColorType type)
 设置控件的颜色模式,默认值为 MaskColorType::CustomColor type
void setFull (bool full)
 DBlurEffectWidget::setFull full 设置时候模糊区域占满整个窗口大小
void setBlurEnabled (bool blurEnabled)
 DBlurEffectWidget::setBlurEnabled blurEnabled 设定模糊区域是否可以伸缩
void updateBlurSourceImage (const QRegion &ren)
 DBlurEffectWidget::updateBlurSourceImage ren 设定模糊区域的背景图片
- 信号 继承自 Dtk::Widget::DBlurEffectWidget
void radiusChanged (int radius)
 信号会在 radius 属性的值改变时被发送
void modeChanged (BlurMode mode)
 信号会在 mode 属性的值改变时被发送.
void blendModeChanged (BlendMode blendMode)
 信号会在 blendMode 属性的值改变时被发送
void blurRectXRadiusChanged (int blurRectXRadius)
 信号会在 blurRectXRadius 属性的值改变时被发送
void blurRectYRadiusChanged (int blurRectYRadius)
 信号会在 blurRectYRadius 属性的值改变时被发送
void maskAlphaChanged (quint8 alpha)
 信号会在 alpha 属性的值改变时被发送
void maskColorChanged (QColor maskColor)
 信号会在 maskColor 属性的值改变时被发送
void fullChanged (bool full)
void blurEnabledChanged (bool blurEnabled)
void blurSourceImageDirtied ()
- 属性 继承自 Dtk::Widget::DBlurEffectWidget
int radius
 模糊效果计算时的取样范围,模糊的原理为:将此像素点和周围像素点合成计算得到得到新的值, 此属性表示像素点周围 radius 距离的所有像素点参与计算
BlurMode mode
 所采用的模糊算法,默认值为 GaussianBlur
BlendMode blendMode
 模糊的应用场景,默认会根据有没有父控件自动判断使用哪种模式
int blurRectXRadius
 模糊区域在x轴方向上的圆角半径,默认值为0
int blurRectYRadius
 模糊区域在y轴方向上的圆角半径,默认值为0
QColor maskColor
 画在控件模糊背景之上的颜色,此颜色的alpha通道值会被 maskAlpha 属性影响 修改此属性会自动将颜色模式设置为 CustomColor,设置后将不能再自动根据窗口管理器是否 支持混成和模糊来自动使用最佳的颜色
quint8 maskAlpha
 maskColor 的alpha通道值。当前窗口管理器支持混成(窗口背景透明)时默认值为102,否则为204
bool full
 如果值为true,将模糊此控件所在顶层窗口的整个背景,而无论控件的大小和位置,否则使用控件的位置和大小 设置顶层窗口的模糊区域。需要注意的时,当控件本身就是顶层窗口且未设置 blurRectXRadius 和 blurRectYRadius 属性的情况下,无论 full 属性的值为多少,都将和值为 true 时的行为保持一致。
bool blurEnabled
 如果值为 true 则此控件的模糊设置生效,否则不生效
