一个美观的可展开的控件
更多...
| | DArrowLineDrawer (QWidget *parent=nullptr) |
| | 构造一个 DArrowLineDrawer 实例
| void | setTitle (const QString &title) |
| | 设置标题要显示的文字
| void | setExpand (bool value) |
| | 设置是否展开以显示内容控件
| | DDrawer (QWidget *parent=nullptr) |
| | Get DDRAWER :: DDRAWER example parent As the parent control part of the example
| void | setHeader (QWidget *header) |
| | Set the title control The title control will always be displayed in the layout header Title control
| void | setContent (QWidget *content, Qt::Alignment alignment=Qt::AlignHCenter) |
| | Set the content control Content control is hidden by default, call ddrawer :: setexpand settings for its visibility content Content controlent control alignment The alignment method of content control in the layout method of content control in the layout method of content control in the layout method of content control in the layout method of content control in the layout method of content control in the layout method of content control in the layout
| QWidget * | getContent () const |
| | Get the content control object
| void | setHeaderHeight (int height) |
| | Set the height of the title control.
| bool | expand () const |
| | Visible to obtain the current content control.
| void | setAnimationDuration (int duration) |
| | Set the time for the visibility of the content control when the animation time is changed.
| void | setAnimationEasingCurve (QEasingCurve curve) |
| | setTheVisibilityOfTheContentControlWhenTheAnimationStyleIsChangedOfTheContentControlWhenTheAnimationStyleIsChanged curve Specify animation style
| void | setSeparatorVisible (bool arg) |
| | Set the segmentation line between the title control and the content control.
| void | setExpandedSeparatorVisible (bool arg) |
| | Set the segmentation line under the content control.
| | DFrame (QWidget *parent=nullptr) |
| | 用于其他需要边框的控件基类
| void | setFrameRounded (bool on) |
| | 设置边框圆角是否开启
| void | setBackgroundRole (DGUI_NAMESPACE::DPalette::ColorType type) |
| | 设置边框背景画刷的种类
| void | expandChange (bool e) |
| | Content control visibility signal e For TRUE, the content control becomes visible, but vice versa
void | sizeChanged (QSize s) |
| DDrawer (DDrawerPrivate &dd, QWidget *parent=nullptr) |
void | resizeEvent (QResizeEvent *e) Q_DECL_OVERRIDE |
| DFrame (DFramePrivate &dd, QWidget *parent=nullptr) |
void | paintEvent (QPaintEvent *event) override |
一个美观的可展开的控件
DArrowLineDrawer 继承自 DDrawer 并提供了了 ArrowHeaderLine (一个带有箭头标示的按钮)作为其固定的标题控件, 也就是说跟 DDrawer 相比省去了提供标题控件的步骤,只需要提供内容控件即可,如果需要自定义标题控件应该使用 DDrawer 类。
- 参见
- DDrawer
◆ DArrowLineDrawer()
| DArrowLineDrawer::DArrowLineDrawer |
QWidget * |
parent = nullptr | ) |
explicit |
◆ setExpand()
| void DArrowLineDrawer::setExpand |
bool |
value | ) |
virtual |
◆ setTitle()
| void DArrowLineDrawer::setTitle |
const QString & |
title | ) |
- include/widgets/darrowlinedrawer.h
- src/widgets/darrowlinedrawer.cpp
- docs/widgets/darrowlinedrawer.zh_CN.dox
